xts3000 MDC issues
viper21
MidTN
Ok I have an XTS3000 and have the CPS for it.. I have enabled MDC and set a primary Id
I have a CM300 and have MDC enabled as well...
My issue is that the CM300 seems to display all other radio's ID but my Xts3000. When keying the XTS I do hear the "squawk" sound on the CM300 but no id appears, when I key the CM300 the ID does appear on the XTS display.
The XTS will display the ID's of the other radios in my dept. I'd like to be able to use the XTS as a backup and want dispatch to see my ID if i use the XTS. I've had other radio's with MDC but I dont know why the XTS is not showing up on the CM300.
Thanks in advance
DPapay
Morris County, N.J.
Are you using the same ID for both? I know when I program two HT1250's with the same ID, they will not display them. The radio will not display its own ID.
viper21
MidTN
Ahhh that was it.. The CM300 wouldn't display the same ID as it's own... The XTS does...
Thanks!
