A model one XTS3000, UHF 430-470 split, programmed with five conventional frequencies, one of them ASTRO only, the other four mixed mode, all receive only. All the codeplug info passes the error check.
When turning on radio, green LED lights during self test, then alternates from dark to lit for four seconds each (lit 4 sec, dark 4 sec, lit 4 sec, etc). It does this for as long as nine or ten minutes at times, then will finally beep that self test has passed, then LED goes dark, and immediately emits one error "boop".
At that point I can press a monitor programmed button and hear static no problem. But no incoming transmissions are received. After anywhere from 1 to 5 minutes, it will go back to the alternating green LED on/off/on/off again, eventually beeping self test passed, then the immediate error boop again.
During one of its "able to get static on monitor" moments, I managed to upload its saved codeplug with no problem. After restarting itself from the programming, it behaved normally for about a minute, immediately passing self test and receiving fine, then dropped into LED on/off/on /off again.
Any ideas?
Any ideas?
