xts3000 question about scan list edit from the radio
wv8mat
Letart, WV
i have a question about my xts3000, i have a switch selected for edit of scan list, when i flip the switch it goes to the scan list edit mode but i cant add or delete anything thing in the scan list, it shows where i can push the button on the front saying sel and del but when i push them the radio just beeps at me. can soneone please tell me what ive done wrong.
thanks
C138NC
Tactical Taco Consumer
NC Taco Command
Who programmed your radio? I never configured a scan list on an xts3000 since i dont use one on patrol, i just use the mobile.
It could be something that wasnt programmed but if i had one in hand i can try it myself and list what you need to do.
So you selected the channels you want added to your list but when you push that button and then select and delete or add, it just beeps on you? mmmm let me do my homework on this one and ill find out or atleast someone else that has it could tell you, i just use it and not worry about scanning :D sorry
skipshark773
Stuck in traffic on I-25
Two things come to mind:
1) The personalities you are trying to edit are not linked to a scan list.
or
2) The scan list has not been properly configured to allow front panel scan list editing.
To check or fix these problems you will need to load/open your radio's codeplug in the CPS. First, check the personalities. Make sure that they have been pointed to a valid scan list by making sure you have a list selected under the "SCAN" tab on the "CONVENTIONAL PERSONALITY" screen. Next, open your "SCAN LIST" configuration screen. Make sure that the "PRIORITY 1", "PRIORITY 2", and "NON-PRIORITY MEMBERS" drop down boxes are set to "OPERATOR SELECT". Once you have made the applicable changes save your codeplug and load it into the radio.
wv8mat
Letart, WV
i almost had it, i selected the channels to scan on the list in my cps and then wrote the codeplug to the radio. let me change a few things around and i wll see if it works
thanks
