XTS3000 Questions
joeyvb
Schuylkill Co, PA
Hey guys i am aspiring Amateur radio operator and EMT/Firefighter for work. im looking into a XTS 3000 radio looking to ask if the ADP algorithm can be put in a 3000 UCM? thanks
73s
Joe
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Thread moved to Motorola forum.
The answer is no. You'll need an ASTRO25 radio or newer to do ADP.
KG4INW
Midlothian, VA
While the 3000 is capable of P25 it was a part of Motorola's ASTRO lineup. The subsequent series was the ASTRO25 line and includes the XTS1500, 2500, 4000, 5000 and perhaps some others I'm missing. Marketing thing I suppose but the newer radios had more features.
I should also add the newer radios also used a completely different CPS package.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Astro25 is Motorola's trade name for its P25 capable radios. ADP is a proprietary encryption protocol that Motorola developed that provides for inexpensive encryption, but it is not part of the official P25 standard. Both are unique and should not be confused.
The ADP in the XTS1500, 2500 and 5000 is available as either a flash and programmed in the CPS or can be a component of the UCM and loaded in a key loader.
To my knowledge it was not available in the XTS3000 due to a lack of manufacturer offering as the radio was already end of life when ADP hit the market.
MTS2000des
5B2_BEE00 Czar
Correct, not to mention the XTS3000/Astro Saber has very limited memory for fimware (1MB) and it's amazing that it supports 9600 baud P25 trunking as it is.
If the O/P wants to put a radio on most Astro 25 systems, most systems admins have a list of supported models they can provide you with. Most of those who administrate Astro 25 systems do not provision legacy radios like XTS3000s and Astro Sabers.
always check with your agencies' system manager or help desk for what radios are supported BEFORE purchasing one.They know best what is/is not permitted on their network.
joeyvb
Schuylkill Co, PA
thanks MTS2000des,
the system in question is a brand new ad still being built... system frequencies were just released and they are only ranges. im going to need every algorithm until i can get a key if at all even possible... if not ill just use it as my amateur radio. got away from the XTS3000 and am looking at either a XTS2500 or XTS5000.
Joe
N4DES
South FL
im going to need every algorithm until i can get a key if at all even possible... Joe
Trying to find one with all of the algorithms is difficult. You might want to wait until the radios are deployed then put it into test mode to find out what type it is programmed with.
Of course the key is another hurdle and you will have to speak to whoever is the system manager is, but somehow I'm sure that will be a difficult item to get.
