Lol. Calm down Mr. professional all I suggested was that he does not absolutely need the tool. And while he has it apart to lube the seal.. Lol. Y would you say not to lube the seal? Is there a reason? I am curious since your the professional.
Did I ever say the Manual said it was OK to use a screw driver , LOL grasping at straws now , huh.
What professionals corrected me? You and Trip? Even Trip said "Technically, you can probably pry it open with a screwdriver, but MOST people end up damaging the case and the O-ring."
Key is MOST people not all. Even you, yourself said it is possible.
Is it recommended by Moto use a screw driver? of course not.
I have opened many XTS radio's without the tool and have NEVER damaged the case or seal. If the tool's had not been misplaced by other techs I would of used it. Oh by the way the tool is actually $7 dollars, the rest of the cost are the legs they put on them to run and hide when you need them.
The OP no longer has the radio and said he was going to possibly get the tool.
This thread should of been dead by now, but you had to come back in, and make your typical RR style comment about me "A guy with the name Hitec giving out incorrect info. Thats Radioreference for ya.."
Since your a professional, you should know how dirty the seal can be, right. So again, your saying not to clean and lube the seal and gasket surfaces (because he is not going for an R rating), LOL.
My ? still stands, Y should he not lube the seal? As you suggest, since I guess I am giving incorrect info on that also.
Do you not see the irony in your logic, get the tool but don't lube the seal because he's not going for an R rating.
So let me break down your Logic, Don't Half A the case , get the tool,,,,, but Half A the gasket.
Need I remind you the gasket is a very important part of the radio, R rating or not.
