XTS3000R Programming ?
Griggs
Hamilton NJ
I am trying to program my XTS3000R, I have the RKN4105A programming cable, but I need the drivers for the cable, can anyone help, or point me in the right direction??
N4DES
Retired 0598 Czar ÆS Ø
South FL
That is the incorrect cable for the XTS3000. You have a cable for an XTS5000/XTS2500 and it won't work for that model radio.
You need a RIB box and the RKN4035 cable.
Griggs
Hamilton NJ
Ahh, I was told by our radio tech at work that it doesn't need a rib box. I will have to do some more interrogation.
N4DES
South FL
whats the major difference between the two??
Totally different cables and programming protocol. You can find ribless cables on ebay but you could end up with a brick if something happens during the programming process.
SD70MAC
NC
cable
I hate to tell you this but I don't beleive the XTS3000 CPS supports USB. And it may not support that cable even if it has both the serial db9 and USB. You may be able to get a copy of an aftermarket cables driver but I have never tried that. I have the RKN4106 DB9 only and it only works with the XTS2500 & XTS5000 . I wish it would work with older stuff to instead of having to carry a rib cable for the HT1000,JT1000,and MTS radios. Mother M has a way of making you buy a cable for every radio. I wish they also would have included the XTS3000 in with the XTS2500/5000 CPS there are alot of the 3000's around.
ddiesel2006
I have an xts3000 cable but need an xts5000 cable if you'd like to trade. PM me if necessary.
