XTS5000 AES-256 problem
Will001
Lexington County, SC
Hello all:
My Xts5000 M1 VHF radio has aes-256 encryption in it, but ever since I change the programming, it does not Tx in encrypted mode. I have all the correct keys, but when I select secure tx, all I get are a bunch of beeps. Does anyone know how to fix this?
rescue674aa
I’m an idiot
You need a KVL to load the keys on the radio
Best you could do with out a key loader is the ADP encryption
Sent from my LG-H343 using Tapatalk
rescue674aa
I’m an idiot
Yeah but if you changed programming then you will still have to load the keys doesn't matter if they are in it still has to validate though a KVL
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That's not correct. There is no validate mode on a kvl.
It's a programming issue. Unless you managed to erase the keys, go back and check your programming.
I thought if the battery on the radio is off for more than 30 seconds or no power whatsoever to the radio that the keys get erased?
Forts
Ontario, Canada
Can you receive an encrypted transmission from another radio? If so then the keys are still intact. As long as you have infinite key retention checked under the secure settings, the keys should survive program changes, battery removal etc etc.
