XTS5000 codeplug without frequencies
Intruderjim
Chicago
I have an XTS5000 codeplug that has all of the frequencies blank and in red? 100% conventional codeplug. Any help?
Thanks,
Jim
N4DES
Retired 0598 Czar ÆS Ø
South FL
You can't remove the frequency totally from the Channel Assignment tab. At a minimum it has to have a default frequency in that that conforms to the proper bandsplit.
XTS3000
I remember this same thing happening to me. All conventional frequencies were blank, and the blank box would not allow freqs to be entered, but rather it turned into a drop down box allowing you to select default freqs from VHF/UHFL/UHFH/800.
Unfortunally I can not remember what I did to make the codeplug do this or what I did to correct it. I do remember it was something easy. I would post this question on BL, as I got the answer from there.
Good luck
Go to View
Then click on Options
Then Click Frequency Options tab
At the bottom there is an option called enbale frequency picklist. Uncheck the box
You will have to reopen the codeplug
Now you can enter the frequency directly.
XTS3000
Go to View
^-----Cha-Ching! Yep, what he said. I had this happen to me, and took me a while to figure WTF was going on. To make matters worse is uninstalling the CPS and reinstalling it doesn't reset this setting.
What would this option be used for in the first place?
