Xts5000 firmware upgrade path
KE4AXW
I am acquiring an xts5000 with firmware version 8 and would like to take it to latest 20.
Is it ok to go direct to 20 ?
Any specific path needed if that wouldn't work ?
rbrtklamp2
Dupage County, Illinois
I just did it today on a radio that R14 version firmware in it. Go in intervals 10, 15, and then 20. It didn't kill the radio but I have to have it retuned now though. Just FYI
KE4AXW
ok, so I have tried over and over with no luck, i have tried multiple versions of firmware. Radio into bootloader mode, flash starts. It starts to download then aborts after about 5 seconds
I have a USB to serial adapter. Port is set at 115k. I can read and write codeplugs fine.
Any suggestions?
chrismol1
Any suggestions?
One last thing to try, try changing the CPS Timers in Options to 15 (max) Can sometimes help communications problems, you may have to make sure the USB-serial adapter in device manager is properly configured, FIFO buffers etc It may work ok with a tiny couple kb codeplug but may not with a large transfer. I also agree, the proper cable is required. I have also upgraded many with a USB-serial adapter.
KD8RFT
Grosse Ile Township, Michigan
Any suggestions?
If you are running Windows 10 or 11, set the target program you are running it in compatibility mode for Windows XP. That fixed it for me.
