XTS5000 Flashcode
importjunky
Hello all,
I just purchased a XTS5000 used, The flashcode thats installed on the radio, the only features enabled are
H37 SMARTNET
H14 Enchanced Digital ID
Q446 Channel Announcement
I need to be able to use the radio on an analog bases. Does anyone know how I can go about getting a flashcode to be able to use the rest of the features on the radio?
Current flash is 500004-000002-3
Firmware R16.00.00
Using an encoder, I imagine I am looking for something closer to this
54040F-100B02-9
Project25_MASTR
TX-COMU
Texas
It's already setup for analog. Flashing the radio will require a flash code authorized ibutton from Motorola and a copy of the CPS.
APX7500X2
NY/CT
I normally put in 5A908A-C01E87-4, That way i only have to do it once and don't have to touch the radio again, and its very nice to have the FPP.
Do real research on how to do it and take your time, All the information is out there, On here you will just be hounded by the radio police
MTS2000des
5B2_BEE00 Czar
and being that MSI stopped selling flash upgrades for the XTS/XTL back in December, or so they said, getting this from an authorized source may not be an option.
importjunky
I believe the ability to program analog channels has been disabled by the previous user.
If someone would be so kind as to email me screen shots of cps to show me where they I can program analog channels?
When I got to conventional personality and add a channel it only list rx and tx options, but nowhere to enter the freqs
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Disabling analog channels isn't possible.
Frequencies are entered in the Zone not the Personality.
riveter
MD
In the XTS, unlike the APX CPS, the actual frequencies used are defined in the zone channel assignment, NOT the personality.
EDIT: Mike was just a hair faster than me...
importjunky
AH!
Thanks that helps a lot!
You would think moto would try to keep the CPS the same model to model :-|
One thing I did notice it the Radio won't allow me to Narrowband, It keeps changing it back to 25kHz.
I noticed Q507 is disabled in the codeplug, which is narrowbanding mandate
Project25_MASTR
TX-COMU
Texas
Should be noted that with the XTS3000 frequencies are assigned in the conventional zone personality.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
What exactly are you trying to do?
Are you changing the Transmit Deviation to 2.5 KHz?
Project25_MASTR
TX-COMU
Texas
That actually reminds me. CPS won't let you change the bandwidth. You have to change the deviation and the bandwidth will change to match.
importjunky
That's that I needed to change!
didn't realize if you set the Deviation to 2.5kHz it moves the Channel spacing to 12.5kHz automatically.
