XTL/XTS5000 XTS5000 How to stop trunking
VNR5338
I have a xts5000 programmed with non trunking conventional frequencies. when I turn the radio on the green light continuously blinks like it's searching for a control channel. When I PTT it transmits for a millisecond then I get the bong tone until I release the PTT. I does receive fine. Just won't let me TX.
Where in the CPS should I look to get all the trunking features turned Off.
Thank You
Richard
Sounds like it still has trunking personalities in the zone channel assignment. There should be no "Trk" in there and only your new "Cnv" personalities
Ant9270
The Green Weenie
If it was searching for a CC, You'd see red blinking from the LED indicator. You won't be able to delete the old system without a key. As stated above, ensure all trunking personalities are removed from your zones. That should solve the issue.
VNR5338
Thank You. I will re-check the trunking personalities. And how would you delete the old system without having a system key?
Re flash the radio??
clbsquared
Isle of Wight County
Add a new default system and then delete the old one. Do the same for the trunking personality. By default, Motorola radios require at least one. The new system will just be a generic 001 system ID. This is assuming the trunking portion isn’t ASK protected.
ElroyJetson
You don't have to remove the trunking data but you can disconnect it from the zone/channel assignments. Or move it to channel 17 in some zone, so you never can access it via the rotary control.
