XTS5000 Narrowband?
beaker7
Boise, ID
So I've been using an XTS5000 for a while now and it has a 12.5kHz option in the CPS and FPP but not in the flashport code. But while browsing eBay and found a radio with "12.5 kHz FCC Mandate" (Q507) in the flashport code. Does this mean that my radio doesn't have 12.5kHz narrowbanding?
My radios flashport: 560000-001306-2
The eBay radios flashport: 588408-901E87-2
Thanks for the help!
yaknamedjak
localhost
I believe the mandate option just *requires* you to have your business band frequencies narrow banded. Otherwise you go into receive settings and change the receive deviation then it will let you change the TX deviation if it doesn't automatically change it.
Every 5000 can be narrowbanded.
FFPM571
Nashvillle
The Ebay radio has been hit with Depot( AKA Lab) software and been whored out with every option available some are even incompatible in the same radio
N1GTL
CT
This is exactly right. If your radio has the narrowband mandate option, you cannot program in wideband channels. This makes radios with the option installed not really usable for amateur radio. APX Radios have smarter logic and will let you program in wideband channels where they are allowed such as amateur and marine..
SFPD92
Stillman Valley, IL
XTS 5000 version 1 Narrow band?
So a buddy just purchased an nice looking XTS 5000 version VHF portable from EBAY. I was trying to program it for him and can not the TX spacing to 12.5KHZ to be compliant for public safety. Any thoughts here?
Project25_MASTR
Millennial Graying OBT Guy
Texas
You have to change the deviation field.
