XTS5000 programing help!!!!!
laozuo225
I try to program my new xts5000. When I try to read the radio through cps r20.01.00 it keep showing an error. "This radio is not supported by this application Error context:a, status: c0001013". Does anyone know hoe to solve this problem?
RKG
Boston, MA
CPS is a type of software; there are different CPSs for the different families of Motorola radios. Specifically which CPS are you using?
laozuo225
I am using the correct cps which is the aetro 25 portable cps and it is the latest version.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Which version of R20.01.00 are you using? Almost sounds like you are using the mobile version of the CPS and not the Portable version.
Giddyuptd
Here and there
What firmware does the radio have in it? Turn the radio on, press the third button on side consecutively until it goes into service mode.
Also is the housing pins dirty, worn or anything with the housing itself or disconnected inside?
laozuo225
host version is R20.50.07 and it works on the Astro 25 tuner
Giddyuptd
Here and there
Try doing a full uninstall of all astro25 products. Restart pc.
Then re install and restart.
Check you cable is it serial or usb?
If not oem is there way to try a alternate cable?
Iogear guc232a if I recall was the go to for serial to USB suggested by M back in day . We never had issues on them back then.
It almost sounds there is a issue with the cps itself.
Find a better link? Lol
rescue161
KE4FHH
Hubert, NC
Are you using Windows 10? Are you using a real serial port with a serial cable, or are you using a USB adapter with a serial cable? If any of those are true, try using an OEM USB cable or use a different computer that is running Win 7.
