well lets see here, you go and spend good money on an xts5000(right), and good money on the CPS(right) (assuming it is legit software) and cheap out on the programming cable(WRONG)... what do you expect??
suck up the moto cost and get a real cable or keep trying fleabay and hope that you dont brick the radio.
why on earth would youspend all that money on software and radio and not get an OEM cable??
This is what i fail to understand... people that spend all that money on a radio, then cheap out on the cable, will be the first to talk about how much junk motorola is because their fancy radio is dead.
I have fixed several high end motorolas that were used on junk cables, and had to send back a few that could only be fixed by a trip to the depot. The end user QUICKLY learned that spending the extra money on the proper cable is signifigantly cheaper than a trip to the depot or an MSS to be repaired.
Used to be cables were simply a DB9 to a radio connector, with at most a resistor in line... not so anymore... while there are some decent non-motorola programming options out there, they usually cannot be had for 1% of the price of an original cable.
but hey, its your FL 01/82....
