XTS5000 QCII Signalling
bReed11091
Battle Creek, MI
How do I program the radio to send out QCII tones?
Also, how do I set a talk permit chirp tone on P25 conventional? I know there are tricks to do it, but I don't have access to the forums that describe it.
Devilz311
NJ
First, under Conventional > Quik-Call II > Quik-Call II Call list; program the sets of tones you wish to transmit.
Second, under whichever personality you wish to transmit the tones on, under the 'Signaling' tab select Quik-Call II as the Signaling type.
Third, Under the 'Quik-Call II' tab of the same personality, select Selective and/or Call alert under "Encode." Then make sure the correct call list is selected.
You can create multiple tone sets under multiple call lists.
Make sure the Channel in the Zone Channel Assignment is set to the correct personality as well.
bReed11091
Battle Creek, MI
Hua on the talk permit tones.
I'll try those steps to get QCII to work. That looks like the same methodology described in the CPS, but the radio doesn't give me a menu option to transmit them. I have CALL and PAGE set as menu options, so I thought it might be a flashcode option.
Devilz311
NJ
My 2500 will send tones using either CALL or PAGE. Whichever signaling system is listed under the personality determines if it sends a QCII or MDC call.
bReed11091
Battle Creek, MI
Tried the setup you described Devilz, but still not seeing CALL or PAGE menu items. Is there something I might be missing? The channel does have the QCII personality assigned to it, and the personality is set to use the QCII system and call list I set up. Selective and Call Alert encode are both checked off, and there are tone sets in the call list.
Jay911
Bragg Creek, Alberta
I don't see how talk permit tones relate to QCII (pager) tones?
The OP asked two questions - one about QCII and the other about talk permit tones.
IIRC, the XTS series of radios needs to have a specific flash for QCII signaling (and it may even be one for receive and one for transmit).
bReed11091
Battle Creek, MI
Thanks for the info. My flash is 500001-000000-8. I didn't see anything about QCII or MDC calling or paging when I decoded the flashcode, so I guess my radio doesn't do it.
bezking
On the Road
Not so fast. The XTS doesn't need to be flashed for QC2. bReed, what's the firmware version in your radio?
KG4INW
Midlothian, VA
According to a BatBoard thread, QCII didn't show up in the Astro 25 line until Host R08.00.00. So your FW is too old.
Devilz311
NJ
Fw version R04.50.00
Are you going by the sticker on the back? If you are saying that you see the options for QCII in the CPS, then your radio may have been upgraded. To check, turn the radio on and press the bottom-side button 5 times after the self-test. It will display the firmware as Host Version.
If you were able to program the tone sets in the radio, make sure the Call and/or Page menu items are enabled.
Radio Configuration > Display & Menu. From the "Menu Items" tab, make sure the Call & Page selections are added to the field on the right under Conventional.
bReed11091
Battle Creek, MI
I'm going by what is read from the radio both in the CPS and when I enter service mode on the radio.
The CALL and PAGE menu options are enabled on the radio.
akarsin
Hagerstown, MD
I know this has been stagnant for a while, but I am trying to get an XTS-5000 to remain quiet until an QCii is received then alert and open.
I have figured out how to send the alert tones and can activate a Minitor III/IV pager.
Any thoughts or suggestions are greatly appreciated.
