XTS5000 Question
mfn002
Bryan, Texas
I recently acquired a used XTS5000R. When I turn it on, it will flash between KEY FAIL and the channel number. It also gives me the option to erase the key, and shows "HwKey 1". This sounds like a trunked radio, but I was told it was VHF conventional.
mam1081
Next to a scanner...
This means that it's programmed to have an encryption key loaded, but one is not loaded. To get rid of that message, you would have to re-program the radio to not use encryption or load it with a KVL.
That doesn't really tell you if it's trunked or not. The flashcode will tell you if it supports trunking, and what type. If you're trying to use it to listen to Bryan's TRS, give up. It'll probably get stunned as soon as you program it up.
mfn002
Bryan, Texas
I'm not trying to listen to trunked on this thing. Just using it to listen to the dozens of VHF agencies around here (one of which is expressing plans to go P25).
43g70
What is the model #?
Does the antenna say Motorola 800 or Motorola VHF?
43g70
mfn002
Bryan, Texas
It was a still-working parts radio, and there is only one label, and has three barcodes with three different numbers on it:
Z329D0003
NUD2865A
329031235
It did not come with an antenna. I suspect the TX circuitry is fried, because I am not getting any RF output; therefore, I can not exactly tell what the freq range is.
FuelForFire
The Garden State
When powering up the radio, immediately after self test press the button above the PTT (the one with two dots) 5 times. This will place the radio in service mode and will scroll thru all of the pertinant information. Post everything it says (except the serial and ESN) and we can tell you exactly what you have and what it is capable of included the band and all of the options installed (i.e. trunking, IMBE, etc).
mfn002
Bryan, Texas
Well, it stopped powering up, but is still drawing current. Did it possibly go into some kind of safe mode or something?
WayneH
Forums Veteran
Super Moderator
Your master site
You've just been inhibited (i.e., your radio was killed). :lol:
The battery is probably at the point where it powers up and then dies.
mfn002
Bryan, Texas
How do you fix this problem?
By the way: I got a new battery today.
WayneH
Forums Veteran
Super Moderator
Your master site
I meant that more in humor. Do you really think your radio has been inhibited? Normally when this happens the radio powers up and tests then goes blank. You can still read the radio too. Read it and reprogram it. If that doesn't work, and you really have been inhibited, then it can only be restored by Motorola.
When you turned it off, was it on a trunked channel? The radio has to affiliate to a system in order for the inhibit command to be sent.
Just noticed you said it was parts built. You probably have other issues then.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Wrong...you can't do anything with a late model XTS/XTL, like the 5000, 2500, or 1500, or a 3000 written to with a late version CPS. Once it has been inhibited, reading it or re-programing it is no longer allowed.
It will tell you right off the bat that it has been inhibited and not allow any code-plug modifications.
mfn002
Bryan, Texas
No, it doesn't do anything. Refer to my statement about it being VHF. It won't power up or test. Just completely blank. No "pop" from the speaker when it powers up. It wasn't parts built, it was a parts radio with a bad transmitter.
n1pj
Sounds like it was inhibited. What trunking system were you trying to listen too. The only way for the radio to work again is to contact the system admin of the trunking system and have them send an inhibit cancel request to your radio. You have a nice heavy paperweight until they do.
mfn002
Bryan, Texas
I never had a chance to program it with anything, so I highly doubt it was inhibited. It came from out-of-state, so the chances of it (if it is indeed 800) having the exact same data channel loaded into it are remote.
If it was transmitting before it quit, I would have noticed it on my scanners (the signal quality will suddenly drop). This did not happen.
JUST IN CASE NO ONE READ THROUGH THIS THREAD, THIS RADIO IS VHF CONVENTIONAL, NOT 800.
rescue161
KE4FHH
Hubert, NC
Is it still not powering up even with the new battery? Dumb question, but is the battery charged?
Have you tried to read it? Even if the screen appears dead, try to read it anyway. That will at least give you a clue as to whether the display is bad and can sometimes narrow things down a bit.
mfn002
Bryan, Texas
Ran the battery over with a voltmeter, reads the specified voltage of 7.5. I have the battery charging anyway. If it was a bad display, it would still turn on and beep, wouldn't it?
I also ran a voltmeter over the circuits inside, and there was voltage there, too; so power is getting there.
The Volunteer Fire Department my uncle works for has a tech who has some surplus CPS software that he's going to send me, so it might be a while.
mfn002
Bryan, Texas
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:confused: I left the battery charging overnight. Still nothing.
