XTS5000 Radio Open Failed
shannondolbow
Hello I have a XTS5000, when I go to read it I get the error Radio Open Failed. I'm using a maxton rib less serial cable, I have also tried this on multiple computers, with the same message.
Any suggestions?
Project25_MASTR
TX-COMU
Texas
What programming cable are you using? What radios have you read with it.
Reason I ask, if it's an XTS3000 (HT1000) cable it will not work with Astro 25 portables.
shannondolbow
The radio that I purchased third let sold the cable with it as well. They had advised that it's worked on the XTS5000 without any issues.
NotATechGuy
NotAMember
Are you using a serial port on the computer or a serial to USB adapter with the cable?
Project25_MASTR
TX-COMU
Texas
There was never a RIB'ed cable for the XTS5000. The OEM Motorola one that initially came out was a direct serial cable at RS-232 levels. Then the USB version came out and once the firmware revisions got past R10 they became extremely reliable for flashing and what not. Drivers were always built into CPS and when using the serial version I always utilized a known good USB adapter (which is permanently slaved to COM 1 on my computers).
