XTS5000 Speaker mic
pvchabot
San Jose
I have an xts5000 model 2 (analog vhf) that I bought off ebay. It has been programmed and functions correctly except that the speaker mic does not work at all. No audio and the PTT switch does nothing. I assumed that I had been given a bad mic so I bought another commander ii. Same problem.
I find it unlikely that I received 2 bad mics but possible I guess. The only other problem I can think of is the internal connection to the exterior connector. The programming cable works so it would have to be a certain pin that is damaged.
Is there anything else I should look at before I have the case replaced?
N4KVE
PALM BEACH, FLORIDA
Before you bought another mike, you should have tried your original mike on a different radio to tell which was bad. Several times I had a radio where the flex that connected to the acc plug was bad. I could have tried 100 mikes on that radio, & none of them would have worked.
pvchabot
San Jose
@N4KVE: Thanks. I will follow up on the flex cable possibility. Does Motorola sell replacement flex cables or am I stuck buying a new case?
@LosRio: The first was normal. The second was commander ii.
Is there really programming required to make a shoulder mic work with the radio?
