I have an XTS5000 thats really been a pain in my butt. Im seriously about to "lose it on the fireline"
Currently, it does not like to recieve anything but significantly strong channels. To quanitfy this, it'll recieve any other portable on simplex within a mile or two, but not further, even if an identically programmed radio is right next to it. It will not recieve repeater outputs on some of our further repeaters even when other units recieve just fine.
I have made sure that:
1. Squelch threshold in all personalities are set low. All are set to 2. Other radios in the fleet are set between 2 and 4 in most cases.
2. I have cloned it from an identical XTS5000 model 3, both via radio to radio clone, and using CPS to clone. Both radios are identical except for one single thing (see #4)
3. It has been tuned and aligned within the last year. The tech even re-cased it (for another issue) and visually inspected its internals including the antenna port.
4. I have tried multiple antennas to rule out a part failure. We are using larsen aftermarket gain whips in the correct bandwidth (upper VHF). I have also tried motorola OEM wideband and OEM VHF correct bandwith whips. HOWEVER. This radio is one that is normally used in an XTVA. Therefore it has the Motorola OEM RF adaptor between the antenna and antenna port. I *HAVE* swapped out that adaptor to confirm it was not the problem...
... And it actually recieves WELL when in the XTVA connected to an external antenna. Which is really confounding the problem.
Anyone have any wild *** guesses on anything else to try before i give up on this thing and salvage its parts?
