saberthree
- Joined
- Jan 5, 2012
- Messages
- 86
I was screwing around with the UCM stuff on the XTS5000 and noticed that you can load up to 48 CKRs in CPS on hardware mode, however out of academic curiosity I decided to see how many keys I can actually load into the radio. It looks like each key set has a slot for 48 keys, I was able to load 3 key sets of 48 or 144 keys without any error codes. Using the same CKR numbers in each key set but individually labeling each key ID. Of course, it didn't actually work as far as being able to switch keysets and using the same CKR with a different key ID, it seems to just default to the first key set. Anyone have any insight to this? I was a bit surprised the radio didn't give me an error code when I started the keyfill. As an experiment, I deleted CKR 1 key on keyset 1 but it seems to delete the other key on CKR 1 slot in key slot 2 as well. Unfortunately, I'm still playing the waiting game for a KVL cable on for my other radio I want to test further asides from, using ADP with only 8 slots.
How is the key set supposed to actually work? How is it managed?
How does index work? i noticed in the manual as well, but It seems I don't have the ability to add it to the screen menu
Is it safe to assume I can only load 48 keys? I mean yeah I get it, how many keys do you really need in a radio?! Thanks to otar for the bigger companies and agencies.
I guess it's safe to assume you can only load 48 keys? I mean heck, if you use one key a month, that's enough keys for 4 years.
