XTS5000 Unmute delay?
beaker7
Boise, ID
Hey y'all, I have been having an odd issue with my XTS5000 VHF M3. It seems to have some sort of unmute delay wether scan is on or off and the unmute delay is at the lowest setting. So instead of hearing "Yes, he is in the lot" I hear "s he is in the lot" its getting pretty anoying and i cant figure out how to stop it. My UHF XTS5000 M3 doesnt seem to do it. Help is appriciated, thanks!
Sent from my SM-G920V using Tapatalk
What is your muting rules for the main conventional personality or personalities with the issue? Double check and ensure AND/OR is used on the main personality window for type. If any mdc is used ensure OR is selected under the mdc windows for the personalities.
If it isn't those check your other settings and match it with the ones that work or you could create a default perosnality and set the and/or in the type and see if it changes. If it does then there is a value that is altered.
