XTS5000 VHF 136-174 FPP Issues
N8VDS
Flint,MI
I have a vhf version that wont take any frequency entry... It shows for instance TX 136.25000 but when i enter a new freq and hit ok it shows <0 in the display and the frequency is gone..... Any ideas ???
Thank's
Randy
ME801
NV
just tried it on my XTS5000 and it sounds like what you doing is the correct sequence. Is FPP enables for the zone your trying to enter the frequency in?
Mikek
Please post your flashcode and firmware version.
N8VDS
Flint,MI
XTS5000 FPP Issues
Flashcode is: 5A9088-801787-4
Firmware is: 20.59 CVN I believe
It will take frequencies in the CPS and radio works on those frequencies. FPP is enabled... Just gives that <0 in the display after entering freq and hitting ok...
Thank's
Mikek
You've got trunking and FPP enabled in your radio - above firmware version 9, those are not compatible options.
N4KVE
PALM BEACH, FLORIDA
Yeah, that's a real screwed up flash code. Something like 520001-001304-7 would work well for you. I recently picked up a few trunking 2500's, but since I'm a ham, I didn't need trunking. But I did need FPP, so I brought my radios to a shop, told him what I needed, & got the above flash code. FPP works perfectly.
KE4ZNR
Radio Geek
Is there a version of firmware that it is compatible with ???
Not without a lot of effort and even then you are stuck with an ancient firmware version.
Basically you can have FPP or trunking with current firmware but not both at the same time.
N4KVE
PALM BEACH, FLORIDA
You don't want to go back to 9 when you're at 20 now. Just get a proper FPP flash code put in your radio. Better than going backwards to 10 year old FW.
ME801
NV
Or buy an APX!
My agency just did got our first APX8K XE to replace our XTS5K's. I can FPP them, but even after installing R20.01.00 and APX USB drivers I still can't read the radio to build the codeplug. (just venting some frustration with the new software)
