For anyone who is interested.......
On Aug 10th Yadkin county made some changes in their frequency allocations. Before then there were 3 primary repeater pairs in use:
Rx 154.040 / Tx 154.950 PL 85.4 (Fire F-1 Dispatch)
Rx 155.385 / Tx 159.405 PL 107.2 (EMS F-4 Dispatch)
Rx 154.740 / Tx 155.535 PL 151.4 (Sheriff F-1, Law Enforcement Dispatch)
For the last year Yadkin has been battling the Tait Quasi-Sync Simulcast system that was installed in 2004. It is a 3 site system with one site being on the East Bend water tank, one site on the Yadkinville water tank and the third site on a tower on the side of Swan Creek Mountian overlooking I-77 / Hwy 21 and Jonesville.
Since day one it has not worked correctly. On the Fire F-1 channel the modulation has been up and down, getting some better, but never what it should be. Although the modulation "sounds" low, you can tell that the console is over deviating most of the time because the dispatchers voice audio is clipping and the 2-tone encoding is clipping (this is really noticable on radios with full "PL" on recieve). There are multiple areas in the southern and eastern parts of the county were 2-tone paging is very, very spotty. Also in these areas the recieved signal from the system is so bad "out of phase" that it is completely unreadable at times on base station radios in the fire stations.
It does not take a rocket scientist to be able to tell the 3 transmitter sites are transmitting "out of phase" with each other. Just tune in during a long dispatch and you will be able to hear it for yourself. Lots of times it is worse in the county than outside of the county, because when listening from outside the county, you are only hearing the transmitter closest to you, not all 3.
The radio shop maintaining this system has been adjusting on it since the beginning and it still is not fixed. At one time you could tune in to any of the 3 main channels and hear them testing on a daily basis.
In recent months an elected county official who has a background in commercial 2-way radio systems has taken it upon himself to investigate and pursue the problems and try to find a solution. After some time looking into the problem a proposal came down from himself, the equipment vendor and the maintaining radio shop.
There were 3 proposals, one was to keep things exactly as they are, and be happy with it. Another was to build 2 tower sites and move the 2 that are on the water tanks to the towers. (This is needed because the water tanks to not provide for the system's required vertical seperation for the recieve and transmit antennas.) The 3rd proposal was to do away with the Sheriff F-1 freq (because they feel like it is causing interference on the other 2 channels) and move all EMS traffic over to the fire channel and move all law enforcement traffic to the EMS channel.
The elected county official made it clear that the county has NO money to further spend on this project and the only option was the 3rd proposal.
So on Aug 10th the change was made. the new freq/channel assignments are as follows:
Rx 154.040 / Tx 154.950 PL 85.4 (Fire/EMS F-1 Dispatch)
Rx 155.385 / Tx 159.405 PL 107.2 (Sheriff F-1, Law Enforcement Dispatch)
This is supposed to be the big fix-all, eleminating the so-called interference and suddenly causing the pagers to begin working properly on the fire channel. Well, guess what...........
Now all we have different is alot more traffic on one channel and the same recieve issues as before.......
Small town politics has once again caused public safety agencies to suffer and move back in 30 years of progress.
Wes
Wes
