KevinTheMule
Hi gang,
I recently got a 2007 2.5L Jetta and took the 8900 out of my Durango because the VW is now my daily driver.
The install went fine until I went to hook it up to the battery as per the manual and like I had it in the Dodge. The problem is it instantly and violently blasts yhe positive 15A @ 32V fuse at the battery in the DC power cord. I had this radio in the Durango for 5 years and never blew a fuse.
The only problem I can see is that the Jetta runs at 14.36V and when revved to 6K goes up to just under 14.5V. Is this enough to blow the fuses? The 8900 manual says it should be ok up to 15V.
I ran an separate 12V/8 amp current through the DC cord and the fuses were ok and the polarity checked out through the system.
Any advice is appreciated.
Thanks,
Kevin
Thanks,
Kevin
