Yaesu FT-270 Eliminating Beep on Transmit
K6SDK
I recently purchased a Yaesu FT-270 and I have had more than one person that I contacted say that my radio is transmitting a beep each time I transmit. Can anyone tell me how to turn this off? I found the bit in the manual on "Tone Calling" on 1750 Hz that is typically used in Europe (I'm not in Europe) and made sure it was set to "MONI" rather than "T-Call", but it's still happening.
Thanks.
Steve
AA4TX
IONAFLXARS0
Look up the "Wires" function in your manual. It will tell you how to turn it off.
gewecke
Banned
Illinois
Hmmm, do you have a symbol in the display that looks like an atom?
If so there is a key on the pad that also looks like a atom, This is for the *wires* feature that will cause you to transmit with a short beep needed to activate a wires internet repeater.
73,
n9zas
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
You have WIRES activated. To de/activate simply turn on the radio and press and release the '0' key. There is an icon in the top right corner of the screen that goes out when you turn off the WIRES function. This is the one stupidest function to have as a top level function, activated by a single key press. HELLO YAESU????? WTF were you thinking?????? why the h*ll is it not buried in the menu with the other un used functions????
K6SDK
Thank You
Thank you! You guys nailed it. The manual says press "0" to turn it off and when I do, I see the atom icon disappear, and I verified that the tone is gone. Now, how do I save that setting? Every time I turn the radio off and on, the atom icon is back. The manual doesn't seem to say how to save the disabled setting.
Thanks again.
Steve
kayn1n32008
Sector 001
Thanks again.
Steve
It may be saved into the memory. Is the WIRES on no matter which memory you power up on? If so you may have to go back and re do all your memories.
K6SDK
Saving WiRES setting off
I don't think I know what you mean by "which memory I power up on". I haven't programmed any frequencies into memory slots.
Thanks.
Steve
Krmit
Victorville, CA
DISABLING THE YAESU WIRESÔ FUNCTION
Page 1 of 2 KB6OT – Revision 1.2 11/29/07
The Yaesu WIRESÔ (Wide-coverage Internet Repeater Enhancement System)
proprietary Internet Connection feature operates by transmitting a short (~ 0.1
second) DTMF (Dual Tone Multi Frequency) tone burst each time the Push-to-
Talk button is pressed. The WIN (Western Intertie Network) System repeaters
are set up to mute DTMF tones. Each time the WIRES DTMF tone is
transmitted, the repeater mutes for several seconds and the first few words of the
user’s transmission are lost.
The WIRES function is turned ON or OFF by momentary pressing the 0 key on a
FT-60 handheld or left VOL knob on a FT-8800 or 8900 mobile radio. The
WIRES function can be disabled so that it can not accidentally be turned on
using the following steps:
FT-60 – See manual page 49
1. Press the F/M key then immediately press the 0 key to enter the menu
mode.
2. Rotate the Dial knob to menu 23 – INT MR.
3. Press the F/M key then rotate the Dial knob to select a memory (d1
through d9) that is empty, i.e. it contains ······ (six dots) = no tone.
4. Press the F/M key to store the setting.
5. Rotate the Dial knob to menu 21 – I NET.
6. Press the F/M key then rotate the Dial knob to select INT.MEM.
7. Press the F/M key to store the setting.
8. Press the PTT button to exit the menu mode.
To re-enable the WIRESÔ mode, select INT.COD in menu 21.
VX-170 & VX-177 - See manual page 48
1. Press the F/M key then immediately press the 0 key to enter the menu mode.
2. Rotate the Dial knob to menu 24 – INT MR.
3. Press the F/M key then rotate the Dial knob to select a memory (d1 through
5. Rotate the Dial knob to menu 22 – I NET.
To re-enable the WIRESÔ mode, select INT.COD in menu 22.
FT-8800 / FT-8900 – See manual page 50 or 48
1. Press the SET key momentarily to enter the set mode.
2. Rotate the Main band Dial knob to select menu 15 – DTMF W.
Wego
Metairie,La 70002
To Fix The Beep When Keying Up On The FT 60R
Hello
# 1 - Push ( F W )
#2 - Than Push ( Set )
#3 - Then Rotate Knob To ( Beep )
#4 - Then Push ( TX PO )
#5 - It Sure Have When ( OUT )
