Yaesu FT-270R and Ni-MH battery ...
speedmaster
Guys, I bought a Yaesu FT-270R recently. I didn't think about it at the time, but a friend tells me it uses a Ni-MH battery and he much prefers lithium-ion. Does anyone a Lithium-Ion replacement battery for this radio?
Can I expect poor performance with the factory battery (memory effect, short life, etc.)?
What similar radios use lithium ion batteries?
Thanks very much in advance!
Chris
texasemt13
CenTex DBA
Hunter, TX
Nope, this thing is a workhorse, and if you got it new, and condition the batteries, it will last a long time.
Fully drain the battery for the first 5 times, and fully charge it each of those times.
I take this HT kayaking with me, and it has no problem with the conditions of Central Texas rivers and Central Texas heat.
W2NJS
Washington DC
Your well-meaning friend should have also told you that your present charger probably will not be able to charge a lithium-ion battery if you do obtain one. First check with Vertex, then check the websites of people such as W&W, Multiplier, and other battery suppliers. Lithium-ion usually costs quite a bit more than Ni-MH and for ordinary use you probably don't need the fancy battery whose two chief advantages are that it's smaller than Ni-MH units and will also hold a charge sitting on the shelf for a much longer period of time. Again, if you do find and buy a lithium-ion battery do not try to charge it in your charger unless you're certain that the charger is what is called a "tri-chem" charger.
