csxcp55
Hi;
I know the basic differences between these two radios. The FT-2900 is 75W with a gigantic heat sink and heavy construction, while the 1900 is 55W and much lighter and smaller.
What about the receiver?
The FT-1900 sensitivity spec is 0.2uV @ 12dB SINAD, while the 2900 is 0.4uV @ 12dB SINAD.
I am really interested in searching out the weak signals (even if I can't work them), so it would appear that the 1900 is the way to go. But how much of a difference is there really between the two receivers?
What may look like a lot on the spec sheet probably doesn't amount to much on the air.
I have also read that the 2900 may be better for rejecting unwanted signals - that would make sense, since a lower sensitivity will generally lead to a better rejection.
Anyone have both radios, and willing to compare with a weak signal? A good signal to listen to is a distant repeater, or for out-of-band, NOAA weather stations from distant city.
Frank - KE2KB
Frank - KE2KB
