gary777
Hi, I have a 60r that has been setting for months, I mistakenly left it turned on, at the lowest volume level. I use a SBH-13 drop in charger. I put it on the charger and after 15 minutes or so to amber light came on for a bit, indicating it was fully charger. I thought that was odd. I turned on the radio and to readout read 8.2V I took a vom and checked the voltage from 3 contacts on the back of the radio using the far right contact and far left contact, got a voltage reading of 3.8v. I have the radio charging again now and it's been an hour and still charging. My question is what should the voltage be when measuring the battery voltage at the battery contacts.
When using the SBH-13 should the amber light stay on when fully charged, or will the light turn off.
TNX KY8M
TNX KY8M
