Yaesu FT-767GX IF shift question
KK4YVX
virginia beach,virginia
Hi
I just got my Tech ticket about a month ago. I bought a used Yaesu FT-767GX. By accident I shorted the 13v and 8v RCA jacks. The result was a dead radio. The outside fuse was good, but once inside the radio I found a 6A fuse in one of the PA units. I replaced the fuse and thr radio came back to life.
However now when I am receiving LSB I have to turn the IF shift knob at least to the 9 o'clock position before I can get the right receive. In USB it works just fine at the 12 o'clock position, the same position I used for LSB before the fuse replacement.
Does any one knows what's caused this issue?
Any help or quidance will be much appreciated.
KK4YVX
After more research I found out that the LSB and USB crystals are the culprits. If any one knows where I can get these parts or what other radio uses the same parts, please let me know.
Thank you
AK9R
Super Moderator
Central Indiana
Do you have part numbers for the filters?
