Yaesu FT-7900R Antenna Quesion
jmilletics
I'm considering purchasing a new mobile rig, and I can't seem to find any documentation of Yaesu's antenna connections for their 7xxx series and 8xxx series.
Can anyone tell me what adapter (if any) I would need to connect my PL-259 antenna mount to the transceiver?
Thanks & 73
-Jason
Good radio!
MFJ makes a nice dual band antenna which comes in either PL259 or NMO connector at the base. But as the other guy said SO-239 is on the radio so you'll not have any funky SMA or TNC adapter issues.
hockeyshrink
My 8800R has an N type connector, so I use an adapter that is SO-239 and N male. I have a SO-239 chassis connector, but have just been too lazy to replace the N connector on the radio.
D00D
I've never seen a 8800 with anything other than a standard SO-239.
N9JCQ
Lake Barrington, IL
agreed. They are all so-239s. Excellent radio by the way. I have two 7800s, one mobile and one in the shack.
zz0468
Banned
Why would you bother? The N connector is a much better connector. I'd lose the adapter, and put an N on the cable.
hockeyshrink
Even if I have the only FT-8800R in existence with an N connector, it still makes you wrong, because there is ONE and it is in my truck.
However, you are correct about the 7800; I use that as a base and it is excellent.
hockeyshrink
You're right, it is a better connector than the SO-239; however, I occasionally change mount and radio combinations depending on what equipment I am running at any particular time, and the other radios I use on that mount all have SO-239s. Good call, tho.
hockeyshrink
I wasn't aware that the 8800R came with a factory N-connector. Or did it?
Awww man, you caught me. Yep, when I unsealed the box I immediately opened up the radio and replaced the SO-239 with the N connector, in anticipation of responding to this post a year later just to confuse everybody and hijack this thread.
:roll:
God forbid you actually are unaware of something.
F-tards
mrweather
Did some digging and it turns out the "export" version comes with an N antenna jack from the factory.
Not sure if you were being sarcastic or just a douche, but thanks for taking the time to reply to my question. :roll:
