How do you receive Air band?
dcr_inc Feed Provider *York Pa.* Premium Subscriber Joined Feb 28, 2005 Messages 1,032 Location Delta, Pa Aug 7, 2020 #2 FTM400 does a GREAT job with Airband RX.. Use mine to get ATIS before arriving at the airport..
VNR5338 Member Joined Nov 24, 2004 Messages 30 Aug 7, 2020 #3 But HOW do you put the radio on the air band. When scrolling through the bands, it does not have the 108-118 range.
M mrweather Member Joined Dec 19, 2002 Messages 1,260 Aug 7, 2020 #4 Did you set the proper receive coverage? If not, go to Disp/Setup->Config->RX Coverage and set to "wide". Access the airband by going into VFO mode and manually keying in frequencies or using the dial.
VNR5338 Member Joined Nov 24, 2004 Messages 30 Aug 7, 2020 #5 That was the problem. It was not set to Wide. Problem resolved. Thank you mrweather.
