Yaesu FT90R Discriminator Tap Point
ka2mek
I have just been on an exhaustive search trying to find good information on exactly where inside the YAESU FT90R that the discriminator tap point for the baseband audio would be located at?Has anyone here done the mod OR has anyone seen anywhere GOOD information on this?I have checked all the ham radio and scanner sites that I know of and turned up a blank.Help.
73!
Robert - KA2MEK
ka2mek
Just found the tap point for this radio.It is in the MIC jack!One of the pins in the mic jack provides BASEBAND audio from the discriminator for PACKET setups.
73!
Robert-KA2MEK
smackdaddy
Hi Robert,
Can you tell us which pin you found it to be? I have an FT-90 in the car, and this would make for a pretty rockin' mobile slicer setup. I'm sure others are in the same situation.
73,
SD.
ka2mek
Yes I Can
Without the aid of a photo here I will do my best to describe this....
Also folks, DO NOT ATTEMPT THIS IF YOU ARE NOT ELECTRONICALY/TECHNICALY SAVVY for you may regret it!Being very serious here now!!! Also I can NOT be held responsible for ANYONE who makes a mistake,you will endeavor this MOD at your OWN RISK.
Now - all that said and done......... here goes..............
First disconect the radio from all power sources and antennas and external speakers and what-not also disconect the MICROPHONE.
Remove the 4 screws that hold the cover on the radio(the cover that does NOT have the speaker on it,the OTHER blank cover)
once that is removed you will be staring directly at the circuit board with IC's on it.Place the screws and cover in a safe place and don't lose them.
Now take the radio and look directly at the MIC JACK with the circuit board side UP.You will see the pins of the MIC jack line up with the solder connections for them on the circuit board,the pin with the base band audio from the discriminator will be here in the TWO sets (rows)of MIC JACK pins soldered on the circuit board,Three pins are in each row for a total of six pins,the base band audio pin is the FIRST pin on the LEFT of the FIRST ROW closest to the edge of the circuit board when you view it as stated above.That was where I soldered the center wire of a THIN audio cable to and I attached the shield (Ground side of the cable)to the screw directly in back of the solder connections for the MIC JACK(Other shade tree techs may opt for another ground point ,thats cool!).Be aware there is ZERO and I mean it cause this is a MICRO RADIO,,,there is ZERO room to work and a lot of margin for ERROR here so BE VERY CAREFUL when attempting this.So I then routed the cable(it is very thin audio cable)along the side of the circuit board and out towards the rear of the radio and exited out where the rubber gasket holds the DC power wires in place,and it came out very nicely.The end of the audio cable that exits the radio I cut and left about a half foot or so and attached a Female RCA Audio connector to it so I did not have to coil up any cable when I transport the rig from home to car and vice versa.Once the cable was soldered in and I was confident that my work was clean and finished and the cable was routed (I opted to TAC down the cable inside the radio with a couple of micro dots of EPOXY to the circuit board for stability) I very carefully hooked the power to the radio and an antenna and ran the audio connection to my laptop MIC input ,booted up T4W, tuned in the 800mhz type II control freq and SON OF A GUN IT WORKED !!!!first time!!COOL!Now after this I disconnected everything and carefully placed the cover back on the radio and secured it with the four screws plugged the MIC back in the jack,and declaired "Its MILLER TIME"!!! So basically that was how I did it,as I said others may opt for variations on this but THAT PIN is where you will get the JOY of the BASE BAND AUDIO from the DISCRIMINATOR out of the mic jack on this radio.It was provided there for by Yaesu for PACKET RADIO hookups and the MOD will not affect the performance of this FT90R at all, The Dual band rig works great on the ham bands and the MOD works fantastic for the application in the use of T4W!Take care - BE aware! and ENJOY!!!
73!
Robert-KA2MEK
General Class Amatuer Radio Operator
Middletown Twp,NJ
BANDIT
Gainesville, Ga
PS: Dont open radio, just get an extra mike plug make your tap with it. It has one pin for 1200bps and the other for 9600bps, the 9600 is the one you really need to use for motorola control channels. :D
ka2mek
Well
I fashioned my FT90R up this way by making the INTERNAL connections for a reason,I wanted to keep the MIC plugged in and not have to REMOVE it and use a seperate pluggin gizzmo every time I wanted to use T4W OR revert back to VHF/UHF ham work with the radio.HEY it works for me :D to each his own I always say.Also if you read my post I so noted that this mod should NOT be performed by just anyone,you will need some EXPERIENCE in working on INTERNAL electronics before you even consider REMOVING THE COVER!So its not for everyone only those who are confident enough and have the SKILL to do it.YES-you can use a J-TYPE MIC plug and remove the MICROPHONE and plug in a patch cable if you have it WIRED CORRECTLY but I opted to keep the MIC plugged in for my particular circumstances and use a seperate DEDICATED discriminator line.Just thought I would post my results here because someone asked me to post my result for others in case they wanted to follow suit.
73!
Dr.Robert Salvo
KA2MEK
