yaesu mobile and a ford crown vic
stevolene
chattanooga metro
I have a new yaesu ft1802 that I would like to install. my question is: is there anyone out there with a crown vic that has actually installed a mobile radio in it? I want to make sure I have a nice clean signal, therefore I figured the best way would of course be directly to the battery, unfortunately, I haven't been able to find any kind of access between the engine compartment and the inside of the car. Any help will be appreciated , thanks steve
stevolene
chattanooga metro
yes I am serious, my crown vic isnt a P71, its all carpeted with no ground bar or accessory hook ups under the dash as the cvpi has, thats why Ive asked this question, all Im looking for is examples, previous installs, and experience........this is to do this correctly the first time..............so please, if I need smarta$$ answers Ill ask my wife
hoser147
Grand Lake St. Marys Ohio
I had a civy version a few years ago, cant exactly remember where I went thru the firewall, but if you look there should be a place to come thru. As for antenna coax there should be a channel in the body right inside the doors under the carpet, that runs from front to back. Hope this helps. Hoser
texasemt13
CenTex DBA
Hunter, TX
I remember most Ford cars have a rubber boot around the steering column up under the dash. On the two Ford installs I've been apart of we just punched a hole through the boot and pushed them through- never had a problem. You might find more options if you are willing to pull your dash off.
Utah_Viper
North Muskegon, MI
Here is my Radio install:
I ran the coax under the base boards to the backseat then into the trunk. The Radio is 'soft' mounted for now where the Ash tray would be in a civ model. I have a CVPI so it may be different in yours. Looking there should be similar entries past the firewall though. I would still look up CVPI Radio Installs as they are very close to identical and can give you some good ideas.
stevolene
chattanooga metro
thanks, I actually found a rubber grommet on the firewall where I believe the speedometer cable is going thru, I ran a small hard wire and it came out under the dash just right of the fuse panel, this looks like my ticket
CCHLLM
On the passenger side foot well, about midway across at the base of the vertical part of the firewall where it meets the slanted portion of the footwell and just above or behind the top of the carpet line, see if there isn't a harness passthrough with a grommet. With a fish wire poked through the grommet, you can pass a wire/cable under the heater components on the engine side of the firewall and route it right to the battery connection on the relay/fuse box.
stevolene
chattanooga metro
for some reason I cant see that picture?
Grog
Banned
West of Charlotte NC
It's hosted on photobucket.
Are you browsing from work or another computer on a network? I know the computers where I work are blocked from seeing many hosting sites so if I look at this page I would just see a blank area where the picture is.
Grog
Banned
Here it is attached to the forum, click it to make it bigger.
stevolene
chattanooga metro
thats nice, but Id like to keep my ashtray, I did find a rubber grommett on the passenger side just below where the carpet line begins, Ill poke thru that to see if I can get some power from there, thanks, that pic looks excactly like miy interior except I have a clock where your trunk release button is
Grog
Banned
also, why are your power wires running towards the back seat?
Not my car but a couple of possibilities...
#1 it could be a power cord running towards something else to power that accessory and not to the radio.
#2 They could have a power distribution block between/under the seats/in the truck out of view.
jparks29
John McClane
Nakatomi Plaza
Co-phased 800 Mhz to null any multi-path transmissions (frequent occurance in urban jungles), UHF, and GPS.
The radio install.
That car has been gone for about 2 years now though.....
My current vehicle is much lower profile, since I only have VHF in it....
Just a 1/4 wave with GPS .
Otto
Portland, Oregon
The radio install.
I hope to god that you are a cop, and that is your work car...
Otherwise, that is pretty whacker-tastic. I mean, I like listening to my scanner, but no way in hell would I want to be driving around in a gas guzzler wanna be cop car.
If you want to be a cop, why don't you just apply for the job?
Whackers....
I just don't get it.
Do something that's at least fun!!!
Grog
Banned
:lol::lol::lol::lol::lol::lol::lol:
John has quite an interesting history, seems the motorcycles don't like him too much more either, do they John? :D
