Yaesu: yaesu ssm-512b not working with yaesu ft-65r
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
When i plug it in and try the ptt button on the headset it doesn't work at all does anyone know if there is a setting on the radio i need to enable? I tried vox and still nothing?
ko6jw_2
Santa Ynez, CA
I believe that there is a switch on the microphone to select PTT or VOX. If it is in the VOX position the PTT button won't work. If the radio is set to VOX the PTT won't work. Check all setting for consistency. Otherwise the headset may be defective. Never use VOX - it can get you into trouble. Most VOX headsets have a sensitivity setting or there is one in the radio menu. This combination seems to have neither.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
I got it to work but to get it to work you have to hold the plug right against the outlet on the radio or else it wont work at all like u really have to squeeze it tight,
