Yaesu Vertex VX-10
FCVPI99
Rockford,IL
i just got a cuple of these from a flea market plus chargers and know nothing about them
i do know they are VHF FM Transceivers
can anyone tell me anything about them??
and if i was to reprogram them is there anything like FRS but in the VHF band??? AKA i want freqs. that i can talk on with no ham lic.
please somebody tell me i did burn 100.00 for nothing
kg4uad
Pickens, SC
The VX-10 is basically the type Accepted brother of the FT-50, a great radio and is field programable once the mod is done, watch out for the power on/off button quirk in which case youll need to clean the circuit board contacts.
73's
Kg4uad
XTS3000
the VX-10 is more like the FT-10. VX-10 is type accepted, and has a voice scrambler option. Both VX/FT-10 are VHF radios.
K2GOG
Mid Hudson Valley
FCVPI99 said:
is there and freqs. i can talk on in the VHF band that i dont need a lic.???
you could program in the MURS frequencies
151.8200, 151.8800, 151.9400, 154.5700, 154.6000
More can be found on the WiKi and also here http://www.provide.net/~prsg/murs_faq.htm
If you live near the water, you may wish to program them for the marine channels.
You could also program the weather frequencies as "listen only" as well as local PD and FD in "listen only" mode as to be a dedicated VHF scanner.
Please note that you should make sure you dont violate any rules regarding the above mentioned ideas.
