- Joined
- Jan 26, 2008
- Messages
- 525
- Reaction score
- 0
GREETINGS ALL, I have a question, I would like to say a qwik question, but I am inexperienced with yagi's, and I guess some of the answers I need are not so simple. I own a Pro-106 scanner, and I have had great luck with VHF using my discone, my discone picks up clear reception up to approx 65 miles. I believe that I want to try a yagi to improve reception on 800 trunking freq's. I already own coax, and a good antenna switch. I think I would like a yagi up on the same mast as the discone. The yagi's I've seen have been designated as cell yagi's, or for 2 meter and ham. A while back I had noticed 2 or 3 yagi's on ebay, and they were being listed as scanner use for 800 mhz. I did some searching of thier model numbers, and found they were listed as UHF 806 to 866 mhz and I would require an adapter for the coax connection. Will this style antenna work for my reception needs for trunking 800 mhz, and would it be worth buying and attempting to direct it at a tower in my town. Keep in mind, the discone does a pretty good job at the 800 freq's in my area, but from all I have read, the 800 yagi might really kick things up a notch, especially when most yagi's have good gain.
