Ubbe
This is a perfect situation to use cheap RG6 coax from a yagi and then in the attic, or wherever the coax enters your roof, you put a low-noise amplifier. That will give you more signal than any costly high grade coax cable can do. You probably need to attenuate the signal 6-10dB down at the scanner to avoid getting into overload issues with too high signal levels Most amplifiers powers from a USB connector so you probably have a mains outlet in the attic where you can connect a 5volt USB adapter.
/Ubbe
Low Noise Amplifier RF Wideband 10-2000MHz; Gain 20+dB; 0.5dB NF PGA-103+ | eBay
Find many great new & used options and get the best deals for Low Noise Amplifier RF Wideband 10-2000MHz; Gain 20+dB; 0.5dB NF PGA-103+ at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Mini-Circuits 6 DB Attenuator 50 Ohm DC to 1500mhz Model Cat-6 for sale online | eBay
Find many great new & used options and get the best deals for Mini-Circuits 6 DB Attenuator 50 Ohm DC to 1500mhz Model Cat-6 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
/Ubbe
