mkewman
holy hell! i'm going to have to try to make one now!
awesome!
awesome!
kf4lne said:I may also see if I can build a VHF antenna for 152MHz for under $5 and post the results here too. I have one for WX band that is made from PVC pipe and sluminum rod from Lowes, but its overall cost was nearly $20 and its only estimated to be 7db. If I can find metal rod cheap enough I think I can do a $10 Yagi for VHF
ROY_PICKETT said:I have about 15 --5' pieces of steel rods ,, would that work for the elements..They are about 3/16" in diameter .. And would PVC pipe work for the boom? Thanks Roy
Well i guess PVC pipe wouldn't work because it has to be metal.. Now i feel a little weird..
dave3825 said:Dan When drilling the holes in the dowel,,
I see the driver holes don't go all the way thru because they are 2 elements but the rest of the elements -- are they done the same as the driver or do those holes go all the way Thru and use one long element????
gcgrotz said:QST had an article in their annual antenna issue last month or 2 about building yagis. It had a real neat scheme for drilling the holes perfectly straight using another piece taped to the boom to mark a line down it and then rotating it to mark another line for the other side. Looked pretty good.
Hey All,
Here is the article that is referred to above:
http://www.arrl.org/qst/2006/11/archive-october.html
Alain
What is the purpose of a gamma match and can you break down its constuction a little more...will be constructing an 800mhz model this weekend.
