Hi guys,
I've been listening to scanners for a long time now. I've really only used the stock or telescopic antennas, so I don't know a whole lot about antennas. I'm planning on building a Yagi antenna for 772 MHz to monitor my local P25 system. The tower is 10 miles from my house. I've seen multiple designs online using different materials and dipoles.
My first question is what material should I use for the boom? I've seen PVC, dowel rods, 1x1 pieces of wood, and aluminium square tubes. From my understanding, only the dipole/driven element needs to be isolated/insulated from the other elements (which do not need to be isolated, but can be). Is that correct? Do the materials have pros and cons relative to the signal or is it just preference?
I have also seen different types of dipoles for the driven element. Which would be best to use? I'm don't know the proper names, but I have seen straight dipoles that stick out like the other elements, folded dipoles that loop around almost all the way, and one that sticks out on one end and loops around on the other. I'm thinking of using 1/4 inch aluminium rods, but how hard is it to bend? Is it best to coat everything with paint or leave it bare metal?
Sorry if this is off topic, but what how far off frequency could I go with a Yagi? I've read that they were only good to up to around 1% off the tuned frequency, but antennas sold online are advertised with a larger frequency range/bandwidth. Either way it is not going to be an issue, just something that I was wondering about.
I like what was done in this thread:
https://forums.radioreference.com/build-your-own-antenna/125567-homebrew-850mhz-yagi.html
I'm going to use one of these calculators:
Online Calculator .:. Yagi Uda Antenna
or
Martin E. Meserve - K7MEM - VHF/UHF Yagi Antenna Quick Designer
What your guy's input? Let me know if you need to me clarify anything.
Thanks.
or
Thanks.
