yellow medicine county Minnesota sheriffs dept
dgully
i cant find a feed that has the sheriffs day to day communications just dead air.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
I just looked, seems to nothing but public works department for YM county???
Highly suggest purchasing a scanner. I'd look at a Uniden BCD996P2 or BCD325P2. Great scanners.
fredva
Virginia/West Virginia
The vast majority of Broadcastify feeds are provided by volunteers who are willing to use their equipment to stream the communications. If a feed for a particular agency doesn't exist, it means there currently isn't a volunteer interested in streaming it. If you want to listen, you will need to get a scanner. There is a note on the database page for that county saying they are transitioning to the statewide ARMER system. That means you should purchase a digital scanner, since that is a digital system. A cheaper option is to look into a software defined radio setup.
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
If DB is accurate and sheriffs dept is still analog there, you can get away with a much cheaper analog-only scanner. No need to spend a few hundred if P25 isn't needed. Welcome to the OP!
k0wpd
Clara City, MN
Yellow medicine Co in Southwest MN is on the 800mhz digital Armer Radio system they only use analog for paging on 154.3100
Main Law TG is 29398
Your going to need to buy a digital scanner that costs 100's of dollars or you can purchase if you live with in 50miles or so of yellow medicine co mn an rtl-sdr usb dongle with unitrunker software or download sdrtrunk software using an rtl-sdr dongle.
See my qrz page for more information on monitoring public safety cheaper then spending 500.00 on a digital scanner.
Take a spare computer and spend less then 75.00 not very portable but you can setup a server and use your phone to monitor it anywhere.
I recommend sdrtrunk free software. all you need is an rtl-sdr dongle
if any encryption is used you will NOT hear anything. just like any scanner without the proper keys.
GitHub - DSheirer/sdrtrunk: A cross-platform java application for decoding, monitoring, recording and streaming trunked mobile and related radio protocols using Software Defined Radios (SDR). Website:
Buy RTL-SDR Dongles (RTL2832U)
Yellow Medicine Co Radio Talk groups listed on qrz.com
28613 6fc5 D UPSAG PARK 1 Upper Sioux Agency State Park 1 Public Works
28614 6fc6 D UPSAG PARK 2 Upper Sioux Agency State Park 2 Public Works
29300 7274 D YMED 911 Yellow Medicine 911 Emergency Ops
29350 72a6 D HAN FALLS PW Hanley Falls PW Public Works
29351 72a7 D WOOD LAKE PW Wood Lake PW Public Works
29352 72a8 D ECHO PW Echo PW Public Works
29354 72aa De G FALLS HOSP Granite Falls Hospital Hospital
29355 72ab D YMED Yellow Medicine Multi-Tac
29356 72ac D YMED COMMON Countywide Common Multi-Talk
29374 72be D UPR SIOUX PW Upper Sioux PW Public Works
29375 72bf D CANBY WORKS Canby public works Public Works
29376 72c0 D CLARKFLD PW Clarkfield PW Public Works
29377 72c1 D G FALLS WRKS Granite Falls public works Public Works
29378 72c2 D YMED H WAY 1 YM Highway 1 Public Works
29379 72c3 D CANBY HOSP Canby Hospital ER Hospital
29380 72c4 D G FALLS HOSP Granite Falls Hospital ER Hospital
29384 72c8 D YMED EMERG Emergency Trigger Emergency Ops
29386 72ca D YMED JAIL Yellow Medicine jail ops Corrections
29390 72ce De YMED LAW Law Law Tac
29391 72cf D YMED Yellow Medicine Multi-Tac
29392 72d0 DE YMED LAW C2C Law Car to Car Law Tac
29393 72d1 D YMED OPS 5 OPS 5 Multi-Tac
29394 72d2 D YMED OPS 4 OPS 4 Multi-Tac
29395 72d3 D YMED OPS 3 OPS 3 Multi-Tac
29396 72d4 D YMED OPS 2 OPS 2 Multi-Tac
29397 72d5 D YMED FIRE EM Fire EMS Dispatch Fire Dispatch
29398 72d6 D YMED LAW DSP Law Dispatch Law Dispatch
29399 72d7 D YMED ROAM County Roaming Multi-Dispatch
If you have any questions feel free to reach out to me via my qrz email.
73's
Tim KØWPD
