Ganuke
Hello. Well as some of you may have read in the general scanning and / or Pennsylvania scanning forums ..... I was recently in the market for a new scanner. Through research on it and with help / information from those who posted in those threads ..... I ended up making that decision on purchasing the Uniden BC346xt. It just arrived yesterday ..... and as of yet I have not gotten to try it out big time just yet.
But the new scanners arrival has lead me to wondering if the antenna I have to use with it is the best I could have based on my preference. My now previous scanner is a Radio Shack Pro 95. not long after purchasing it going on 5 years ago ..... I purchased the Diamond RH77CA antenna ( with BNC connection ) to use with it.
That previous scanner and the Diamond RH77CA antenna has been through alot over the years. The antenna does have a slight bend to it which just doesn't seem to want to go completely straight any longer. That in itself may be lessening signal / reception strength ..... maybe. But beyond that ..... as I said the antenna has a BNC connection. The new Uniden BC346xt scanner I just got has a SMA antenna connection. But it does come with a SMA to BNC adapter. So my wondering there is ...... will that adapter be lessening the signal / reception strength vs. if I just purchased a new antenna with a SMA connection that will fit right onto the BC346xt ?
So that is the background. And as I said above ...... even if there would be little / no signal or reception strength loss from the slight bend in this antenna or the SMA to BNC adapter use ...... that still leaves me wondering if now 5 years later ...... is there a better all band antenna on the market that I could purchase ? It would also need to meet my preference of not being a ' big ' type antenna ...... in other words I am not looking to get an antenna to mount in my attic or outside ...... and am not looking for an antenna to attach to my vehicle.
I'm wondering about an antenna that I could attached right to my Uniden BC346xt ..... and carry around. Is there one available now that is better in signal / reception strength ( gain ? ) ..... as well as in frequency coverage ( all band ? ) ..... better than my current Diamond RH77CA antenna would be to use ? And if there isn't any better antenna available to purchase than the Diamond RH77CA ..... because of the slight permanent bend to the one I have ..... as well as the SMA to BNC adapter ..... would you recommend that I purchase a new Diamond RH77CA antenna with a SMA connection to fit right onto my new Uniden BC346xt ?
So far I've done a litttttttlllllle researching of this on the Internet ...... ( but really up to just a couple days ago was in the research / decision mode for which new scanner to get.
) I also did use the search feature here at Radio Reference both for just this forum and site wide ...... and most of the results I get in posts ( at least anything decently recent ) seems to be talk about attic / outdoor / car type atennas ..... using coax, etc.. Like I said above ..... I'm not looking for that kind of antenna setup. Just what would be the best antenna to attach right onto my Uniden BC346xt and carry around.
Antenna length shouldn't really be an issue for me. I think the Diamond RH77CA antenna is around 15 inches in length and I've been fine with that over the years. And I would imagine if there is a better antenna out there to attached right to the scanner ...... they wouldn't be too much longer. Also while I am looking for info / opinions / etc. on the best antenna I could purchase ( meeting my no attic / outdoor / vehicle type antenna ) preference ...... I guess I would also prefer the flexible type antenna over a hard telescoping type. ( I'm not clumsy ..... but think that a hard telescoping type antenna would be much more prone to being snapped in half. ) And I also wonder about a telescoping type antenna ...... if there is always the need to extend its length to the frequency range I'd want to listen to. I'd prefer to be able to pull in as full a frequency range as possible without having to adjust lengths to pull in frequencies from one range at the cost of not being able to receive frequencies on other ranges. Still though ..... if you feel there is a hard telescoping type antenna out there that is better than a Diamond RH77CA ...... don't hesitate to say so. If I get one like that I will just have to be more careful with it.
Hopefully everyone hasn't been turned off from the start of reading this post in thinking " NOT Another Which antenna is best Question " ....... and left the thread with no response. As I said I did use the search feature here at Radio Reference and still came up short on the info I am looking for. So please do reply .....and thank you in advance for doing so .....
Ganuke
Ganuke
