I just ran the updated version on my desktop (Win 7 Home Premium 32-bit) and it worked with no problems on a folder with 200+ audio files I've collected on a newly minted Phase II system here locally.Hmmmm... I was thinking the C: was causing a problem but I just tried it and it worked fine.
Can you open a command prompt (DOS window) and try running it from there -- type the name of the program and supply the full directory path/name on the command line and/or at the prompt?
Has anyone else been able to run either version of the program and get output?
My executable is in my "Downloads" folder, and the 'report' html file was sent, as designed, to the desktop.
