troymail
Silent Key
OK - this helps -- I need to work on the section of code that determines if the input folder exists or not. I think the error check I'm doing there could really be several different things but only indicates the folder is not found/valid.
That error might be returned for several reasons:
- folder is not valid
- folder is empty
- folder contains files but not *.wav files
- folder contains too many files
Thanks -- I'll work on this -- or at least make the error message more clear to indicate the above.
- folder is empty
