redchord11
- Joined
- Apr 4, 2008
- Messages
- 21
- Reaction score
- 0
Hello all,
I've been messing around with my Pro-96 and have Win96 all setup so theres no issues there.
I kind of just don't understand how to program it properly. Here's an example of what I did:
I live in NYB Bklyn South- so I went over to the trusty RR database and used bank0 as my NYPD, FDNY, EMS and some random things (which I'm now realizing probably isn't a good idea to mix all that?)
- http://www.radioreference.com/apps/db/?ctid=1855
Using the "Channels" TAB I plug in the frequencies for the various Precints and I get mild traffic but not nearly as much as I thought I'd get. I feel like I'm not using the radio the right way , almost conventionally and not trunking. If I hear a dispatch and then a response- once they go off air- it'll scan through my other banks- Do I have to disable all other banks when wanting to listen to 1 thing in particular?
Rx Modes- which require MOT rather than FM?
I also don't quite understand how to program talk ID's and talk groups- does that box in the bottom right coincide with the frequencies I input in the left box?
Using the RR database sheet - I see PL tones and Input frequency- are these necessary to enter into win96 and if so- where?
I know I have A LOT to learn and I eventually will- but it's just a bit confusing at first.
Here is a screen cap of my .p96 I made- I basically left everything else set as is since I currently don't know what all that other stuff is yet. I found a premade .p96 from pa2600.com and was comparing- but I know it's area dependent. Any insight would be much appreciated.
Thank you for reading this babble as I know my post is all OVER the place..
