Seikowatchman
I'm back after a while away from the radio scanning scene having been rather disappointed with a Radio Shack scanner ( I can't recall the model but it wasn't the easiest piece of kit I've ever used. Then I had an AOR unit which was a vast improvement. After some long drawn out cancer treatment and an interest in building electronic devices for the grandchildren I recently bought a Yupitero MVT7100 from the dreaded Ebay. £45 which at the time seemed a bargain as all it apparently needed was a replacement memory capacitor/battery.
Taking it apart was easy after studying several Youtube videos. I was however surprised to find when measured the voltage across the item was 4.5V. Not too far off the normal 'fully energised' 5V. I replaced it and also re-soldered the speaker and battery connecting wires which had been previously poorly soldered in place by whoever fitted the previous capacitor/battery. It made no difference at all. The scanner receives perfectly but refuses to remember anything. Total amnesia !
I have thoroughly cleaned the keypad contacts and carefully cleaned the keypads themselves. Everything else works except its memory. I even get the 'double beep' to say it's all been entered correctly but I still get 'clear' displayed when I start it up.
Any suggestions as regards anything else I can check before I have to admit defeat and put it in for repair would be hugely appreciated.
Thanks for taking the time to read this,
Chris.
Chris.
