York County - HARRIS RF COM - p25 System
derpotts
baltimore
i have a question.i have an pro 96 i programmed the York co system . i cant pick up anything it stop on digital channel for a couple seconds but no audio.i remember someone saying something about custom tables. how would i set them up and what are the frequency
ocguard
PA/MD
It appears that a license has been applied for and granted to place a transmit site in Whiteford, MD. The address is that of Harford County/Maryland State tower on Whiteford Rd. Does anyone know if there is actual equipment in use here? There is also a location on this license for the York College.
lancopa
So if they go ahead with this upgrade, prepare for a new expensive scanner.
700 MHz
Phase II P25
Well atleast there are scanners out now that do Phase 2. Sucky, I thought I'd pick up a cheaper 396xt, I'll have to get one of the newer unidens I think instead.
TAUNGST
Im having same problem as derpotts.... I have pro2096. My GRE picks York up fine from Harford County, but my pro2096 has no audio and hangs up a few seconds.... I downloaded the file from RR but no go... any help or something I need to do on my end with the program?
TAUNGST
Update, I just reloading York and its getting audio but sometimes Im getting data noise or open carriers.... any help is appreciated... Its for PRO2096
W3DMV
Gettysburg, Pa
Ocguard... Do you have any other info on the Whiteford site post ?
I was unable to locate either a license or application... Was gonna
give a listen, Call sign/Frequency ?
ocguard
PA/MD
It looks like this thread has died.
Not a ton to speak of. The system is in normal operation and there have been few issues.
There is a 2017 timeline set for the upgrade to 700mhz Phase II but there isn't much chatter about details. And very little information (actually, none) has been shared to subscriber agencies regarding the need for subscriber equipment replacement.
I placed a trouble ticket for a barrage of CC Scan and Band Scan occurrences late last summer/early spring. The tech that came out, after explaining to me that tropo skip from a co-channel TV transmitter somewhere to the east was inundating the control channel's ability to stay connected with the radios, also told me that the existing tower footprint for UHF-T will be completely insufficient for 700mhz implementation. So adding and replacing towers will almost certainly be needed.
That said, with 2017 less than two years out, I've heard nothing of physical actions toward the upgrade.
jimsmowin
WRIGHTSVILLE, PA
i was told MD. tower is getting psp 700 mhz on it.also was told york co is set to be live early 2017. thats all i know. and thats not much
mlmummert
Basically the system is mature and working ok now. I suspect you'll hear a lot more about York County if/when they do the 700 upgrade.
PAFF1952
York, PA
I'm not sure if you've seen this info...
911 Radio Upgrade
k3jim
Not getting Central system
All of a sudden I have no reception on the P25 truncked "central system" control channel 500.3125 mhz. I thought I had a scanner malfunction but when i programmed in the North and south systems they work fine. Did they add a new control channel ? Don't know but wonder if anyone else noticed.
Septa3371CSX1
Drexel Hill, PA
Being that this is a Harris IP-25 system any channel can act as the control channel. Make sure you have all of the frequencies programmed in just in case they switch to a control channel not previously used as one.
W3DMV
Gettysburg, Pa
Control channel, "500.3125" is on the air and loud here in Gettysburg. As
the post above states, make sure you have all channels programmed
because they do change....
ocguard
PA/MD
Harris P25 systems allow any site channel to be rotated in as the control channel. Make sure you're checking them all.
markandjere
Franklin County, PA
While listening in the vehicle fire today I caught tg 20008 and 20012. These don't fall in line with YC talkgroups . Anyone know what these are. I did hear a reference on 20008 as being a Fire Police channel.
markandjere
Franklin County, PA
search and you shall find:
Adams County
20008 4e28 D Fire Ops 9 Fire Ops 9 Fire-Tac
20009 4e29 D Fire Ops 10 Fire Ops 10 Fire-Tac
20010 4e2a D Fire Ops 11 Fire Ops 11 Fire-Tac
20011 4e2b D Fire Ops 12 Fire Ops 12 Fire-Tac
20012 4e2c D FirePol Main Fire Police Main Fire-Talk
