Observed System Technical Data
This morning 12/12/04, I noted on my Pro-96 while manually on frequency 868.7750, a control channel noise with line 4 rotating as follows
96:T0101 00-88%
96:BEE00 00-88%
96:SY509 00-98%
The CC noise is faint and the high % numbers are quick so I may be to far away to receive will.
Line 4 Sys data alternately changed with no set pattern, 2 sec to 12 sec.
It appears this will be a 9600b digital system--the first in our area--and the system ID will be 509.
Also, 867.7750 has a faint CC/digital noise with line 4 indicating
96: ----- 00%
With a week signal I seem out of range for Pro96Com, because the display remains on
V-Scanner
PC/IF Port
Remote Acces (this line does not change to***IN USE***)
CLR to EXIT
Anyone on the Peninsula with a Pro-96, please try to collect data with Pro96Com.
BTW, the signal on 868.7750 is stronger in my dining room, so my next step is to copy Pro96Com to my Laptop.
Will advise.
