York Region District Border
Drifter420
Ontario
I have always had a rough idea of where the border is for each district in york, but I never knew where it was exactly for each district.. does anyone know?
I know for sure it's hwy 7 between york and toronto..
Unless York sold off part of the region to Toronto the southern boundries have always been Steeles, not hwy 7. Here's the list as I remember it:
1&3 Districts are accurate for sure it has been a while since I've roamed the southern areas though so forgive minor errors.
1 District
Northern limit Ravenshoe Road
Southern limit (from west to east) King Road, Bloomington Road, Stouffville Road
Eastern limit York/Durham line
Western limit Highway 27
2 District
Northern limit Bloomington Road
Southern limit Steeles Ave.
Eastern limit Leslie Street
Western limit Bathurst Street (I think, might be Yonge).
3 District
Northern limit is Lakeridge road aka Durham 23
Southern limit is Ravenshoe Road
Eastern limit is the York/Durham line
Western limit is also Lake Simcoe
4 District
Northern limit King road
Eastern limit Bathurst or Yonge (see note for 2 district)
5 District
Northern limit Stouffville Road (there is an overlap with 1 district for a bit of turf north of that)
Western limit Leslie Street
Hope this helps. The map isn't that clear.
Drifter420
Ontario
Thanx Wheelie..
Just wanted to update my map book to show which area covers where
Sounds like you're in my neck of the woods.. I'm in Virginia Beach (Dist. 3)
Now I know for sure which district to listen to when I'm in those area
Frequent York destination is Skeswick (Dist. 1), newMarket (Dist. 1), Woodbridge ( Dist. 4), Buttonville ( Dist. 5 ).
Do you know which Fire Dept. Covers Virginia Beach/ sutton ???
p.S. I didnt know OPP repeater 410.4125 was active for this area.. Just fartin around and they were talkative for Sutton area.. you probably knew that.. but since OPP moved to Apco 25 I didn't scan any of the ol OPP stuff.. :shock:
You're welcome Drifter.
I'm actually in Willow Beach so I'm not that far.
Fire coverage is provided by Sutton, station 1-6 and east of Woodfield Rd is covered by Pefferlaw, station 1-8.
1-6 will be dispatched via the trunked system for most calls but will also have volunteers toned out on the old vhf system. Pefferlaw is all volunteer so they are always toned out on the old vhf (153.665).
You can also pick up any of the important OPP stuff on the York police trunk 3 district. There are 2 OPP (OPP 1 and OPP 2) units that share the coverage of this area and work from the 3 district station. If they get a call from the OPP dispatch, they end up coming on the York air to advise of the call too.
You should also be able to monitor EMS by plugging in the Fleetnet system for the Edgar tower and then monitor the Georgian York North talkgroup. Down in that bottom end you'd want to program in the King tower and monitor Georgian York South.
Lots to hear so happy monitoring.
Very useful.
I think that patrol areas were changed around last year but very informative none the less.
More accurate than my memory.
Thanks. :wink:
Drifter420
Ontario
Thanx everyone..
So Wheelie
I have one bank for york police and another with York fire.. just didn't know whic TG they would be on.. but nice to know it's on VHF stead of scanning for all the stuff that I don't need.
Does OPP use district 3 patch? of just Dist. 3 TG ???
You'll usually hear OPP 1 & OPP 2 on the 3 District (most always patched with 1 District) air. They actually use a York Regional portable radio but are also equipped with the fleetnet radios and can, if needed talk with their own dispatcher. This is mainly because these units have one giant patrol area from the 404 right on up to Orillia and who knows where else. But they always talk to the York dispatcher even when taking a call from their own dispatch. So, if you monitor 3 district, the OPP repeater frequency and every once in a while SIM 11 you'll hear what little OPP activity that there is. Even when OPP1&2 are not on and say there's a major accident on highway 48--you don't need to hear OPP to hear what's going on because along with fire you'll have 3 district respond and deal with things until OPP digs up a car to actually do the reports.
BTW, once fire is paged on the VHF channel, you can use that York fire trunk to continue listening to the call. Usually within the page out the volunteers will be asked to respond on Bravo *. The "Bravo" talkgroups 2, 4, 6 and 8 are used by all 3 Georgina stations, all 3 East Gwillumbury stations and Central York (Newmarket and Aurora). They use Bravo 2 as a dispatch and operations channel and B4, B6 and B8 as incident command talkgroups. Note: Richmond Hill uses the odd numbered Bravo talkgroups in the same way.
Sorry for an entire book for such a short question but it was the easiest way I could think of to respond. Hopefully it allows you to happily monitor.
