DSDPlus YSF decoding w/DSDPlus 2.145 & 2.155
NO6B
Walnut, CA
I've found an issue with Yaesu System Fusion decoding: if the signal gets weak for an extended period or another format such as NXDN48 is decoded, YSF voice decoding no longer works. DSDPlus must be closed & reopened in order to continue decoding YSF. This problem was also present in the previous 2.145 release.
When the problem occurs, the DSD+ text window displays some extra text with series of [number][r or m] as follows:
Sync:+Fusion e:6r6m6r6r6rRouting: Src:KE6EMQ VIC Tgt:??? Uplink:???
Downlink:K6PUW
Sync:+Fusion ERR1 e:6m6r6r6r6m
Sync:+Fusion ERR1 e:6r6r6r6m6r
Sync:+Fusion e:6r6r6m6e6r
Sync:+Fusion e:6r6r6m6r6r
Sync:+Fusion FICH CRC FAIL
Sync:+Fusion e:6r6m6r6r6rRouting: Src:KE6EMQ VIC Tgt:********** Uplin
k:K6PUW Downlink:???
Sync:+Fusion e:6m6r6r6r6m
Sync:+Fusion e:6r6r6r6m6r
The errors are due to weak reception, but again restarting DSDPlus restores YSF voice decoding.
Bob NO6B
