Zone 4 In Thunder Bay
Mark_Space
The Great White North
Hello, everyone...been a while since I've been here...
I have a BC-296D, which I have programmed with all the Zone 4 frequencies from the database. I have followed the step-by-step instructions on how to set up trunking, and they appear to be entered correctly.
The problem is, I'm not hearing anything. My scanner is in ID Search mode, and locks on the Hazelwood tower, with signal strength consistently maximum. This same scanner worked fine when living in Kingston, with lots of traffic from the OPP, MTO, etc.
I've searched through previous postings on Zone 4, and it appears there should be SOME activity...
So, somebody rent me a clue...what am I doing wrong?
hodet
Timmins, Ontario, Canada
Do you use bcTool? If so I would be happy to look at your .bct file. I don't know much about zone 4 but wasn't there a thread not long ago that not all OPP had moved to Fleetnet yet?
MetalCarnage
Ajax Ontario
Nope, as it stands right now, MOH and MTO are the only two that have made the move
SpaceMan
Marathon, Ontario
Mike_Oxlong said:
A lot of OPP detachments have made the transition.
Check the database for the talkgroups.
i think most if not all of them have...in thunder bay i hear thunder bay, nipigon, schriber/terrace bay and armstrong and in marathon i can hear marathon, manituwadge, geraldton and longlac...the only ones i havent heard are farther west towards manitoba...
bosco911
NW Ontario
Mark Space....what are you using for a control channel? I have tried setting up a custom search on my BCD-396T but cannot seem to locate a control channel in my area (fort frances). If anyone else has any advice it would be greatly appreciated.
MetalCarnage
Ajax Ontario
I stand corrected, i hadnt turned on my scanner in about 2 weeks, decided to turn it on tonight and am in agreeance, at least in Thunder Bay its fully operational and DAMN is it so much better to listen to then NOR, i have the little jack 'o' trades antenna that came with the BCD396 and i get OPP full bars and crystal clear, so much better then before, lol
